bublitzjos
Thread starter- Joined
- May 2, 2012
- 9
Hi I am new at this site and would greatly appreciate some help on a couple things. First off i just got this boat a 72 starcraft and it has the johnson 65 hp outboard, It is the hydroelectric and i have the johnson hydroelectric lower unit oil in it when i go to start it the prop turns with the flywheel and the remote is in nuetral I am not sure if the switch in box is bad or solenoids in lower unit. i hear 1 wire with power is nuetral, both wires with power reverse and no power in both is forward, i went to check this theory and had power on first wire i checked then i bumped wire against powerhead and made small spark but now i get no power coming from starter solenoid is that now bad, and the shift thing any help would be appreciated. thanks
