'72 Johnson 100 hp - Won't shift into Reverse - Blows 20 amp fuse
Old Finlander
Hi there,
I have a '72 , 100HP Johnson Hydro-Electric Shift that blows the 20 amp fuse when shifted into reverse. I'm thinking the reverse solenoid is grounding out, but not entirely sure. It goes forward and neutral ok. Is there a way to test the solenoids using the green and blue wires and a volt meter? It may be something totally different but I thought I would start there. Thanks for any help.
Honorary Supreme Mariner
Disconnect the blue and green wires att the back of the motor.-----Take an ohm reading on green wire to the engine block.-----Now do the same on the blue wire.------They should read the same.-----My guess is the wiring harness (shorted ) to the solenoid and NOT the solenoid itself.
Old Finlander
Ok. Disconnected solenoids at knife connector and took readings Green to block = 26.2 ohms, Blue to block= 100.6 ohms. They're different but don't know what they should be.
F_R
Those readings are way too high. Should be 5-6 Ohms each.
Old Finlander
Thanks for the help F_R. I went out and double checked using 2 different meters - same thing. Green to block = 26.2 ohms and blue to block = 100.6 ohms. I went from the green to multiple spots on the motor including the ground wire from the casing to the block. Same with the blue wire. So, I feel those are my readings. Does that mean the blue (reverse) solenoid is shot, and the Green (forward/neutral) is half shot?
Might as well remove the lower unit.----Test ohm readings from wires to the lower unit casing.----As stated your values are nowhere near correct !
F_R
My guess is that the wires are burned or rotted away. You will find out when you get the lower unit off.
Old Finlander
OK = Racerone and F_R. You were right! I dropped the lower unit and the cable was squished by one of the bolt heads that hold down the water pump cover. Maybe it was shorting out there. So I took some ohm readings and this is what I found, Green to casing = 6,0 ohms, Blue to casing = 6.7 ohms. What a difference! The outside rubber casing of the cable now has a split in it. I wiggled the wire around and the reading did not change. I don't get it. I would think the reading would change if there was a short. Anyway, do i need to make it waterproof? Are these readings OK to put it back together? Thanks again, Dave,
