72 evinrude... no spark??
donduxk
Hi, I have 65 hp 1972 evinrude outboard motor, it has ran great and always starts right away, it abrutly stopped running and will not start the motor turns over when i turn the ignition but ive tested the spark on all 3 cylinders and theres none, however it did briefly spark once when i was showing my father the problem but only once maybe then no more. Ive brought the boat to my normal boat mechanic and hes baffled by it, If anyone has any ideas please help. Thanks DD
Bob_VT
Re: 72 evinrude... no spark??
Welcome to iboats .......
I will move this to where you will get an answer ;)
Dale Speck
Intermittant spark..., Could be the wire for the kill switch gounding out, very carefully inspect all of the wiring inside the cowling and let me know what you find. On the older motors years of vibration causes chafing and wear through of the wiring insulation.
