72 evinrude gas tank fittings
tony1117
I recently just purchased a 5 gallon metal gas can off off a friend.while hooking it up the fuel line the outboard motor side fit just right with a good seal but on the other end of the fitting that meets the gas tank was being pushed out by two pins that prevented a good seal to the gas tank.The tank is empty and has no gas in it but I am curious why those pins are pushing out the hose line if anybody could help me resolve this problem it would be appreciated thanks a lot..
tony1117
I am trying to upload a picture of the gas can so everyone has a better idea. Thanks again!!
boobie
You have a bad hose line connector. One of the pins vents the tank and the other lets the fuel out when the fuel line is connected.
tony1117
The fitting fits the fuel and air "prongs" just fine ..it's just the two very small pins above those "prongs" you can kind of see what I'm talking about in the picture link I posted...still a bad fitting you think?? Thanks again!!
Honorary Supreme Mariner
The 2 small pins are valves with a spring on them.--One lets are in and the other lets the fuel out.--Are both small pins sticking out the same amount ?
tony1117
Yea they are both out the same amount...would there be a reason why when i snap in the fitting those pins don't compress
tony1117
There is a picture of the smaller pins up top giving me problems..thanks everyone
???--------There are springs on those 2 pins and those springs will push the fitting away from the housing !!
I used to replace the o-ring on those 2 valves on a regular basis about 45 years ago.--Have not done any recently.----It sounds to me like there is nothing wrong except some cheap aftermarket connecter perhaps !
tony1117
Ok I will look into a new connecter for it..thanks for the help..figured it was just something dumb I wasn't seeing!
cloudix
I have three OMC type plastic tanks, but don't recall seeing anything other than the two "prongs". Should all tanks have them? My tanks have something like this: fuel tank connector.jpg
