iDriveAVan
- Jan 30, 2013
- 5
Recently picked up a 16' runabout off craigslist. Has a 1972 Evinrude 85hp V-4 Crossflow motor on it. Model number 85293R. Electric Shift.
I know very little about outboard motors and am have a heck of a time getting the thing to run. When I first tried to start it without doing any work it wouldnt even try and catch at all. I have a 12v battery charger that has a 250amp engine start setting so i know its not a battery amperage problem.
Since buying it i have done the following
-Cleaned up every electrical contact I can reach without pulling the power head off (including contacts in controls)
-New fuel tank
-New Fuel line/primer bulb
-New spark plugs all around
-Checked that all 4 cylinders have spark
-Mixed fresh fuel. added slightly more oil than a 50:1 (approx 40:1)so as to ensure motor was properly lubricated after sitting.
-Checked compression. Cylinders have 110,115,120,125 psi.
-Pulled carbs and found them all gunked up. Fully disassembled and cleaned with carb cleaner and compressed air. Did not remove jets.
-Checked floats and made them parallel with top of float bowl.
-Rebuilt carbs with new carb kits.
After rebuilding the carbs the engines still would not start and i found that the float needle on the upper carb was sticking, and not letting any fuel into the bowl. I took both carbs apart and used a little WD40 to lube up the float needles and the bowls fill up fine now. Engine still will not start. Thought i may have a fuel pump issue so I pulled the pump off and disassembled it and ended up breaking a piece of plastic on the inside so I am working on finding a replacement fuel pump.
With the fuel pump bypassed i have used the primer bulb to fill the bowls and try to start again, no luck. With starter fluid i can get the engine to catch and run for 30 seconds but it wont stay running, even if i squeeze the primer bulb to put pressure on the fuel lines. I then found labeling on the engine for 4 low speed mixture screws and backed them out 1/2 turn from seated but that did nothing either. I cant seem to find any info on what the factory setting on those screws are supposed to be.(See Pic)
So where should I turn next?
-New fuel tank
