That is GREAT NEWS!!!!
Nice work!!
There's a member here who has TONS of knowledge.. Found a write up of his carb tuning tips..
http://forums.iboats.com/forum/engin...-by-joe-reeves
^^ There's the link in case you haven't seen it.. lol..
Ideally, you'd want to adjust idle and final mixtures on the lake.
Biggest reasons for this, backpressure on exhaust, and engine load.
If you're setting these at home, (muffs or barrel..) you can get close.
Once again, I'm at camp so don't have my manual, but I think idle rpm should be around 7-800rpm.. That is on the lake.
On muffs, there's no backpressure on the exhaust, so you'll need to set final idle to about 1000-1200rpm. Then when you get it on the lake, the backpressure drops your Rpm.. but you should be able to get it close on muffs or in a barrel..
Just bring all the tools you'll need to tune carbs again, and set idle when you get to the lake..
It'll be close and run good in your driveway, but with those settings, it'll probably run bad on lake.. you WILL have to do final adjustments on the lake..
You did the link & sync on it too right?
Since you took off and cleaned the carbs, put them back on and got it running, I'm guessing you did, but.. Did you? LOL
As for having to hit the choke....
Usually, that's a sign of running too lean.. (as far as I know,. lol)
But, check out that link above, and if after that fine tuning, if you still have to use choke to keep it running, then when it starts to die, instead of hitting choke, squeeze primer bulb from fuel tank..
Does that keep it running too?
Which remote do you have for it?
Mine has a "Start Lever" which advances the throttle a little, but then mine is a Johnson too, so...
But yeah.. Going to need that little bit of throttle on initial start from cold no doubt..
