1stboatguy
- Sep 8, 2017
- 12
Hi guys I have searched so many forums and can't seem to find what I need to get my motor running so I am posting for help. It is my first boat motor but I do know a decent amount about engines and what it takes to make them run.
It is a 72 Evinrude 50 hp 50273c and has evinrude push button shift controls
The main issue is that it won't start.
Has spark, compression, and fuel.
There is no attempt for the brand new starter to spin when the key is turned. the solenoid does have power to the top and when I turn the key the two middle terminals are getting power but it does not send power to the starter. Some sort of kill switch engaged?
I have noticed that while attempting to turn it over by using jumper cables directly to the starter that is turning the prop and appears to be in gear. I am wondering if this particular model needs to be in neutral to start? It did seem very close to starting a few times while starting it this way but to no avail.
How do I get it in neutral if it does need to be there to start?
I have tested the push button wires with a test light and they do change according to the different buttons selected but the prop does not spin freely when neutral button is pressed.
I have read about the electric shift/hydro electric shift and definitely goes a little over my head and I am not even sure if I have this or not.
I hope this is something simple that I am missing and I appreciate any advice or ideas to move forward!
Thanks
Thanks
