72.....9.5 Johnson Seahorse no water pumping
Goldfam06
I have a 50yr anniversary edition Johnson Seahorse 9.5. Changed the impeller and still no water coming out the telltale. Removed again and ran the lower unit in water using a drill to spin the shaft...water came out of the fill tube, still no water out the telltale. Ran water hose to telltale exhaust and water comes out the lower unit exhaust and fill tube. Help I'm confused why no water is pumping
F_R
Honorary Supreme Mariner
Do you have it deep enough in the water? This is the time of year that everybody gets them out of the shed and test runs them in a bucket. Water pump bulge must be well submerged before starting the motor.
oldboat1
Didn't think the '72 had a tell tale, but maybe wrong (or PO installed one). In any case, check the t.stat and replace if defective. Make sure the t.stat housing and bypass is clear, no corrosion. Test for overheating -- IR tester is useful.
Goldfam06
I do have it on a stand and in water, well submerged in water. Just took the thermostat off and it's missing...no water in there at all. Will that make no water flow out the exhaust telltale? I flushed water into the thermostat tunnel and it went though the exhaust and telltale.
I think it does because hot air blows out the telltale
oldboat1
You should be getting a good spray of water out of that exhaust port on the back of the leg. You might pull the l.u. and try pumping water up through the water tube -- may clear a blockage that way. If you can get water up to the t.stat, you will probably be fine. Don't run the motor yet.
[edit. And always possible the tube wasn't correctly seated in the grommet at the pump, or that the rubber grommet is damaged or missing.]
HighTrim
Sounds like your water line missed its connection when bolting up, or pinched in the grommet?
Grease the water line well, and the grommet. Ensure it slides up smooth into the grommet before bolting up.
Have to ask.----Did the copper tube come out of the powerhead when lower unit was removed ?
Goldfam06
Yes the copper tube came out with the lower unit. Is there a rubber grommet that goes around the top of the copper tube?
Is there a website that has an exploded parts view?
Well, you see that tube is supposed to stay up there on the 9.5 hp.----It will not go back in the right place unless you are as lucky as a dog with 2 $%#%$-----The tube has a pushnut on it to kkep it in place.-------Many websites will give you the breakdown of the parts.
Crosbyman
warineengine.com pick the year and model for part list change my W for a M in the link
Goldfam06
Thank you for the help!!
So I lm order to get the water tube back up into the top end I have to take apart the power head and reassemble?
No, ----You have to remove ( not take apart ) the powerhead to re-install the water tube as per design and the way it left the factory.
ultra353
It's not hard to do just very time consuming . Since the 9.5 have the clamshell design the powerhead sits down deep. You will have to remove the outer shell to get at the motor and this is step that takes some time to do . I suggest a factory manual or just take many pics. I've done about 3 or 4 now and I feel pretty confident now tearing them down. The first one is a little intimidating.
