72' 50hp power head help!!
Denny8112011
So, my 1972 evi rude 50 hp power head is in need of rebuilding. Little history: Compression is 120/90. Have had the motor for two years and ran great. Rebuilt lower unit and carbs last year, new spark plugs, new coils. I'm finding that the owner before me did repairs and used the red silicone gasket material everywhere! Clogged up many ports on the engine(which I've since rectified).
Now on to the powerhead, I figured it's gonna be cheaper for me to rebuild than buying another engine that could have more problems to fix and another money pit. I've already taken powerhead apart. One if the piston rings is stuck and it has one small groove on the piston. My plan is to rebuild the powerhead, have a machine shop bore out both cylinders.
So my question on this motor is can I use a powerhead from a newer year model on this motor? I've found several 81' and up decently priced. Having a hard time finding a powerhead rebuild kit for my year 72'. Would rather rebuild but if I can find a rebuilt powerhead that works might just go that route.
Any thoughts or directions on the powerhead swap?
Thanks!
Faztbullet
You will need to find NOS OEM oversize pistons to repair. This model used a dome piston where other loopers use a flat top piston. That why your having hard time finding some. Slezebay could be your friend...
Faztbullet
Check the cylinders for roundness as these wear bad around the ports from side thrust of piston This makes them hard to set idle and bogg and dieing going into gear problems as weak crankcase compression. A compression test tell you nothing about condition of a engine other than cylinders are close to each other and cylinder can support combustion. That motor from factory had about 145psi new.
