72 1150 water tube
KurtAyres
What holds the upper end of the water tube in place in the top of the drive shaft housing/bottom on engine block? While trying to reinstall my lower unit, the tube came out. When I try to reinsert it, it won't "stay" in place; it just falls out again. The parts manual doesn't show any kind of seal, etc., that I can find.
Re: 72 1150 water tube
put a little grease on it and try to rotate it into place. it should be a friction fit, but if the edge of the water tube catches the end of the seal, it will hang up. Make sure the water tube has no burrs on it.
KurtAyres
I have a new seal on the way. The water tube itself is pretty beaten up, and my understanding is that the part is "obsolete"--and I haven't seen anything about a replacement. Is it standard hardware-store size copper tubing, or will I just need to make the one I have work?
