71 Rude Rich and Lean
dsinger
Does any one know the standard lean and rich adjustment for a 71 115hp Rude. You have a lean and rich adjustment on both carbs. Motor also ran great witht he hood off but sputtered around with it on.
dsinger
Re: 71 Rude Rich and Lean
FAQ is sill messed up I need the carb adjustment section that is the only step by step I have found that works and my print got wet.
tashasdaddy
email me, request carb adj. i've got Joe Reeves saved 'tashasdaddy@comcast.net' agree it works great.
jimmbo
Motors that run fine with the hood off but not as fine when the hood is on quite often are injesting their own exhaust.
Xcusme
(Carburetor Adjustments - Two Adjustable N/Vs)
(J. Reeves)
Initial settings are: Bottom high speed = seat gently, then open 1 turn out. Top slow speed = seat gently, then open 1-1/2 turns.
Setting the high and low needle valves properly:
NOTE: For engines that DO NOT have a shift selection, obviously there is no NEUTRAL position. Simply lower the rpms to the lowest setting to obtain the low speed needle valve adjustment.
(High Speed) Start engine (it will run pretty rough), shift into forward gear, take up to full throttle. In segments of 1/8 turn, wating for the engine to respond between turns, start turning in the bottom high speed needle valve. You'll reach a point whereas the engine will either start to die out or spit back (sounds like a mild backfire). At that point, back out the needle valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest setting.
(Low Speed) Slow the engine down to where it just stays running. Shift into neutral. Again in segments of 1/8 turns, start to turn the top needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running. Eventually you'll hit the point where the engine wants to die out or it will spit back. Again, at that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting.
When you have finished the above adjustments, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
tashasdaddy
exusme, posted them, and i resent.
Walker
Don't have my books handy, but the initial setting on some of those early 70's motors is 5/8 turn open.
Walker
Okay, I dug an old book out and your initial setting will be 7/8 turn out from lightly seated.
