71 johnson 2 horse head gasket - sealant?
twocyclemania
I'm replacing the head gasket on my 71 Johnson 2 horse. I notice that the original gasket looks like it has no sealant of any kind. With the new one, should I shellac-it, Hi-Tac-it, or leave it bare like the original. thanks!
ultra353
Re: 71 johnson 2 horse head gasket - sealant?
If the new gasket has a shiney or sheen look to it then a sealant is already applied.
boobie
If it doesn't say "use no sealer", then you should use OMC gasket sealing compond or Permatex # 3.
twocyclemania
Too late! I already installed it without sealant. The gasket had a sticky covering I found out when I pulledoff the cellophane wrap it came in. I've been running her and she's not overheating as before. Guess it was the head gasket. Thanks for the advice!
boobie
Then you should be okay.
twocyclemania
Boobie and Ultra: Thanks for the input; it's always appreciated. Right now she's running great but with my luck and ability to screw something up I'll be back for more help. Always appreciated!
