'71 johnson 125HP overcharging
Mouse1
Have a '71 Johnson 125HP, running great. Problem is, is running about 16 volts @ WOT. I had replaced the clipper & rectifier last year and it was fine. It's about 14 volts at idle. Just don't want to fry the battery or my CDI.
Thanks for any suggestions.
F_R
Honorary Supreme Mariner
There is no voltage regulator on that motor, so like thousands of other motors, it will reach up to around 16V. You could have installed one of the new combo regulator-rectifier units. Or just ignore it like everybody else does if they don't have a voltmeter to tell them the voltage..
oldboat1
Think if you start with a fresh battery, fully charged, the rate might be a little less. Or go to a two battery system (starting and house battery), using a battery switch. Set to "both", the charge will be split between the battery banks.
Mouse1
Thanks. Would anyone know the number for the combo regulator/rectifer?
F_R
CDI part number 193-3408 for the regulated one. 153-3408 for the unregulated one
