markymarc1
- Jan 24, 2009
- 5
I'm a first time boat owner in the Phoenix area, and want to thank you for any suggestions to help me get this motor running.
Yesterday I spent a half hour pulling the starter and got it running one time. When it started, the motor began revving higher and higher, then it started to revv lower until it quit. It ran for maybe 15 seconds.
This morning, I revisited it, and it started on the first pull. I was nearly in tears. Then it revved up, then revved down, and it quit. It ran for 15 seconds or so. It wouldn't start again after that, despite twenty more attempts on the starter.
Here's what I can tell you:
---The motor has new spark plugs on it. The spark plug wires look a bit worn, as they have fine cracks on them.
---I took out a screw below the choke and pumped the primer bulb on the fuel line to see if there was any obstructions, and the fuel flowed clean. I reinserted the screw. There is flow to that point, if it helps.
---I tried spraying starter fluid with the choke pushed in, then pulled the choke knob out and tried starting. No luck.
The previous owner did mumble something about it idling fine, but didn't run consistently in gear.
I'd like to try and get this running (and learn about the motor along the way), and am willing to do whatever the next step would be.
Any suggestions? What would you check or do first?
Thanks alot!
Marc
Thanks alot!
Marc
