71 Evinrude 50hp Stuck in Fwd
johnnycat
Boat runs fine in forward, but won't go into neutral or reverse. It just started doing this the last time i took it out (last week). I haven't worked on outboards before,<br /> but have ordered the manual and can probably find my way if someone can point me in the right direction.
shade788
Re: 71 Evinrude 50hp Stuck in Fwd
Does it have a separate cable for throttle and shifting or is there only one cable from the control box?<br /><br />If it has only one then it is an electric shift engine. I believe some Johnson/Evinrude models from 68 - 71 were electric shift. You should see two wires, one green and one blue, that go to the lower unit from the rear of the power head.<br /><br />There are coils in the lower unit that cause the engine to shift into neutral or reverse. If there is no power the engine stays in foward. <br /><br />First thing I would do is check the wiring from the control box to the engine then back to where it goes to the lower unit. The manual should help you out with that.<br /><br />Other than that I am not too familar with outboards myself.
johnnycat
Shade,<br />It has two cables but I believe you may be right ont the electronics. Thanks for the info.
jimmmmay
My 71 evinrude 40 hp is doing the same except it wont go into forward only neutral and reverse? I have heard the shifting shaft could bend or pop off, but i am in the same boat! Please let me know what you find out.
