71 evinrude 33 horsepower gas problems
kthurman1
I have a 71 evinrude 33hp that has had the carb. rebuilt. It will idle fine but has trouble when I try to give it gas, it acts like it is not getting any. I can squeeze the primer bulb and it will run fine for a while but always goes back to same problems. I was wondering if this sounds like a carb. fuel pump or gas line problem. Any suggestions will be appreciated.
Monte1961
Re: 71 evinrude 33 horsepower gas problems
Fuel pump! But is the fuel tank vent open? Just in case it's not?
kthurman1
Yes I have the tank vent open, I was thinking fuel pump also but just wanted someone to back me up.
Monte1961
You might if it doesn't already have 1? put inline fuel filter in also! just a thought.
Scubaproh20
I feel really dumb all of a sudden , is an omc tank supposed to be partailly open during operation?!?!?!?!?!?!?!? I'm missing power but lack actual hunting bogging etc and I am certain my pump is good
Monte1961
yes vent needs to be open during operation. Primer will only get hard when you first pump everything up. At that point after fuel pump takes over and squeeze bulb will get soft. But if you still have to pump bulb back up in order to get HIGH RPMS, look in to fuel pump.
