71 chris chraft
KD0FKE
ts got a Merc. V8 OMC out drive as what i've been told the sn: on the block is 476654. i have a pain in the butt wiring problem. all of the wires from the plugs past the one connector in the motor housing are all dry rotted. i have not been able to figure out how to fix the mess my uncle got me into (free boat for some yard work) he replace the original alternator with a acdelco one. and then he had to put in a switch in the motor housing to turn the motor off... it seems as if the "voltage regulator" is missing in the boat or i just miss interpreting it. I had found a shematic for the original harness I can post later if need be.
Should I just replace the amp guage with a voltage guage, wire the altermator to the batter with some 6awg wire and that fix most of the issues besides replacing the original harness one wire at a time?
