'71 9.5 Sportwin Upgrade
Frank Bas
Does anyone know if there's an aftermarket kit available to make it ready for morse controls and a steering cable? I've seen a picture of it once but I don't know where it came from. <br />And, did anyone ever rebuild the carb, using plain sheets of sealing material? I need some information on this because there doesn't seem to be a carb kit available for this engine, and my local dealer keeps telling me I should cut my own.
steelespike
Re: '71 9.5 Sportwin Upgrade
I have made gaskets for all kinds of carbs from the teens to the 60s. Cars,outboard and inboards<br />lawn mowers. <br /> I have also reused gaskets in a pinch with pretty good results.<br /> Have you ever made a gasket<br />using a little hammer to cut it out?
ezeke
The carburetor kit OMC/BRP #382048 is still available from a J/E dealer.
Frank Bas
Ezeke, thanks for the number. A quick search got me to a complete tune up kit from MasterTech Marine. Fortunately they ship to Holland, so I expect to have it running again next month. <br /><br />By the way Spike, you mentioned using a hammer to cut out gaskets? Does this mean you use a chisel? The only thing I could come up with was a pair of scissors...<br /><br /><br />Frank
ezeke
Frank, <br /><br />I've thought of trying one of their complete tune up kits for the 9.5HP. I would like to hear how that works out. Maybe you could post back to this thread when you are finished. <br /><br />Bill (MasterTech)has a great reputation and has always been helpful to me, so I am glad that you were able to connect.
Frank Bas
Ezeke, <br /><br />I'll keep you informed as soon as I receive the kit. Meanwhile, I'm still looking for some sort of bracket to hook up a remote handle on my Sportwin. I've built a hydroplane (the Atomite from www.svensons.com/boat/), but to drive this thing using the tiller <br />would be kind of silly. <br /><br />Frank
tashasdaddy
iboats store, has the connection kits. look under steering and controls the controls then accessories.
ezeke
There was a Remote Control and Steering Connector Kit for the 9.5. OMC Part Number 171879 (Complete Kit).
There was a kit for pulley steering OMC Part # 377440. It has two pulleys.
There is a Top Mount Control Kit OMC Part # 171796. That is the throttle control. It is not a remote but with a steering package it could replace the tiller.
Send me an email and I will send you back the pictures These are all the parts that I see that were specific to the 9.5.These are only the parts for the motor end, not the helm.
Also check this: 9.5 Remote
Frank Bas
Happy to inform you that I finally found the bracket and lever to replace the tiller on my Sportwin. I came across the website of Sea-Way in Seattle, which apparently stocks any old part you need. <br /><br />Thanks again Ezeke for the part numbers. I'll send you an email for the pictures.<br /><br />Frank
