Re: 71 60 hp johnson sometimes fires
I am having this same problem with my motor. I bought this motor from a guy that bought it from a guy, etc... I have been in the process of fixing it up, and it has been running halfway decent which has allowed me to work on the carbs. I never could get it to run exactly right. I just checked the ignition by looking at the plugs (which are new, gapped to .030) I get a real weak spark at all of the plugs. made sure the points are set correctly .010 at all three lobes. I tried the amplifier test in the manual and couldn't get any voltage reading on the output of the amplifier, yet I was still seeing some spark at the plug. I can also hear the amplifier ticking when the ignition is on. I have removed the clipper from the system per advice that I have read here and repaired the bad wiring in the harness (intend on replacing harness completely). I have looked at the distributor components and am suspicious of the "rotor button" as it looks old and the connection points are somewhat corroded. could these parts be bad, causing me to lose voltage before it gets to the plugs? does my amplifier sound like it is bad? I tried using an automotive test light at the blue output wire from the amplifier and get nothing, but when it is connected to the coil (which is new) I get the weak spark at the plugs. what do you think? thanks for all the great info. Waterhole
