71 25hp evinrude clutch dog
woodducker
How would i be able to tell if clutch dog and forward gear had a problem. the gears in the foot look great. there looks like a slot for a shear pin im not sure if one is needed or not.
tashasdaddy
Re: 71 25hp evinrude clutch dog
link did not work, you can view diagram here, follow prompts "http://www.evinrude.com/en-US/Accessories/Literature/?popup=true"
F_R
Most people look right at them and can't see the wear. Look where the ears on the dog bang up against the recess in the gear (rotate it in there). If there is any rounding off, they are shot. It takes surprisingly little to make it jump.
Slot for a shear pin???? Are you talking about the profile ground inside the dog? There is supposed to be a spring and two balls in the hole in the center of the shaft, and the balls click into the ground profile to make it snap firmly into gear.
woodducker
It looks like a slot on the forward gear and a slot on the housing. I didnt know if a shear pin or key is suppose to be there or not.
woodducker
Are the dog and forward gear hard to come by in this year model if not would my local marine shop carry them?
F_R
Part number 384566 gear superceded by 390972
Part number 316501 dog superceded by 390030
I'll let them tell you the price. I don't want to be responsible for your heart attack.
woodducker
Thanks F R,
Your Tha man! And i know they are not going to be easy on my pocket. I might try to check on ebay or locally at the marine junk yard. Ill let you know what i find out. Thanks again
wbeaton
LOL - Let us be the bearers of bad news, FR! The gear assembly is around $500-600. If you buy a used lower unit on eBay for $300 you'll still save tons of $$$.
Here is the photo again.
changetires
Thank goodness mine looked really good for a 1970 40hp and countless hours of operation on it.
