70s 6HP Evenrude Low Power
mikeschumann
I have a 70s vintage 6th Evenrude 2 stroke that was running great. A couple of months ago it started running with noticeably reduced power. Sometimes when I was running full throttle it would suddenly fix itself and get full power back. Any ideas on what the problem might be?
Daviet
Re: 70s 6HP Evenrude Low Power
Dropping a cylinder, high speed orifice plugged. You might try pumping the primer bulb when it is acting up and see if it helps.
tx1961whaler
Check the spark with a spark tester. Bet you're losing spark on one cylinder.
Tim Frank
Unless there is a compression issue, (intermittent nature makes that unlikely), it is either a fuel or ignition problem which you can trace with basic troubleshooting.
If it were me, I'd check ignition system first.
hidef
Can you post the model number? There is a tag on the transom mount it will make it much easier to help you. Depending on the age your engine it either uses points and a condenser or an alternator driven CD ignition. When was the last time any preventive maintenance was preformed on the engine. Clean and rebuild the carb, check the fuel filter screen, replaced the fuel lines not to mention the water pump? If you have just started running gasoline with ethanol your carb could be getting plugged up.
mikeschumann
The model # is 6102G. I had it serviced recently, but that didn't help. I'm not very confident of what the service guys did or didn't do.
mikeschumann
The motor doesn't really bog down. It just doesn't seem to put out as much power as it used to. I have it on a 12' aluminum boat. With one person, it used to run on plane quite well. Now, while the boat is on plane at full power, it is running nose high.
Squeezing the primer bulb has no affect.
