70hp precision blend yammy no crank??
Bankonit9
Help!! I have a 15ft whaler sport circa 1985 with a 70 hp 3 cyl two stroke yamaha outboard(86 I think), that will not crank. The boat ran great all last summer but when I went to winterise with fuel additive it cranked a few times then quit cranking all together. The battery has 12.6 v all gauges lights and aux power are working, when I turn the key I get nothing not even a click? Any help would be great! Thanks
bently
Check voltage at the ignition switch and then the starter solenoid, if you have power that far then your starter or solenoid might be bad.
