I have been working on a three cylinder, 1981 Johnson 70hp outboard. The motor runs pretty well but it doesn't like to idle for very long and it's response to the throttle is very sluggish.
I have re-built the carbs, checked the compression, cleaned the fuel filter, linked and synced the carbs, measured TDC to check the timing pointer, and put in new Champion spark plugs. The choke solenoid also works as it should.
The engine starts pretty easily, idles around 550 rpm, and WOT is somewhat over 5000 rpm. (That is not an easy measurement to take.)
The only strange thing I see is the idle timing is about 12 degrees ATDC. I have not measured the WOT timing. The idle timing seems very late to me.
Can someone tell me if this is reasonable, and if it is not, what do I do about it?
Thanks.
Thanks.
