70HP Johnson No Start
Cottage55
I have an '86 Johnson which has been very reliable for over 20 years. It now will not start. For some time it has had a loud buzzing sound from the controls on start up but it ran fine so I ignored it. Now it will not start. It has fuel but nothing, not even a sputter. Dead man is on. It did this once before and cured itself but now it happened again and I am at a loss. Nothing under the cover looked wrong, loose or out of place. Any suggestions?
1983 ercoa 21'
Does your motor have the vro system on it and in use ?
does the bulb pump up like it should?
have you tested for spark?
flyingscott
Check for spark the buzzing could be the warning horn starting to fail. Your motor is almost 30 years old time for somethings to fail. Check for spark if you have none I would point you to the cdi box.
1983 ercoa 21'
he stated it wouldn't start. That's why I suggested checking spark.
1983 ercoa 21'
Let's see why it won't run then we will figure out the horn .
the horn will not keep it from running!
Cottage55
Has fuel - bulb pumps up. Has Spark. Buzzing sound is only on start up (when it used to) so it is not overheating. No cylinders are firing so no need to check which ones are working. It worked great - then would not start - then worked great - then would not start. When it runs it is fine and does not falter so I don't think anything is loose and I don't think it is fuel filter because when it runs it is strong. I thought of loose connection on dead man but it is not intermittent and has never stalled when running.
1983 ercoa 21'
If I understand you correctly you have tested spark it jumps a 7/16 gap strong?
the fuel bulb pumps up like it should.
if you're getting fuel and getting proper fire it should run but it's not so the compression needs tested! If the compression test passes.
you might have a problem with primer/choke have you checked to see if this is working?
you can put pre mix in a squirt bottle and squirt it in carbs to see if it hits.
Cottage55
Great idea. Maybe the choke is not working. I don't here the click of the choke solenoid. I will check that next.
flyingscott
Cdi boxes were called that long before cdi electronics came about who I am pretty sure used to be called Rapair. Your vro working or not doesn't matter until you get it fired up. I will assume either working or premix as it was a running motor . The cdi box is the ignition controller on the side of the motor by the peehole black box. You either don't have air, fuel or spark you need all those to run. You have a primer flip the red lever to up and its the manual override now pump the ball. Try to start
flyingscott
Evinrude calls them power paks sorry i am old school but i remember when they were called cdi boxes. Also i made a mistake i think the handle has to face down for manual operation
