70hp Johnson losing HP
MikbLoy
I have a 95 Johnson 70 HP 2-cycle that has run with no issues since purchased new until now. When running good it runs at about 5400 RPM. It has started losing HP intermittently. I will try to describe this without making it confusing. Once the engine gets warm (about 5 min or more of running full throttle) it will drop from 5400 to 4k rpm like a switch was flipped. Then after a short period of time varying from 1 min to 5 it will recover and start to run normally again. It seems to be almost predictable that when I turn the boat I can make it happen and once straighten our it will recover shortly their after but that is not the only time it will happen. Sometimes it will oscillate like it was affected by waves cycling in 0.5 sec ON 0.5 sec OFF oscillations. Any ideas?
flyingscott
Do a spark test when that happens and compression test. Your switchbox could be going bad.
Chinewalker
I concur - the intermittent factor points to an ignition issue. If you can narrow down to a single cylinder affected, first try swapping a coil around and see if the problem follows the coil. Also, make sure all pack and coil grounds are clean. Warmed up motors can affect ground contacts.
