70hp evinrude running hot
mustangjay
Hi guys im having a problem with an out board i just purchased i got it not runnng i replaced the selinoid, starter, and rebuilt the carbs it runs great now firt time i started it i noticed the pee water got hot so i shut it down opend the thermostat housing it was full of old salt im assuming from not being washed b4 sitting i took the thermostat out completely untill i make it to the marine shop for a new one i cleaned out the the inside best i could and ran water threw it i restated it and it idles great and pee water is cool so i throttled it up to about 3000 rpm and after a few minutes the pee water was warm not super hot but warm and the exhuast box on the side seemed to get hot more the top left part where is slopes down...but the head was warm to the touch not hot at all...
My question is could there b a blockage in the exhuast ports or is this heat normal? The motor is a 1977 70hp evinrude. Model #70773s....
This is my first experience with an outboard but i am very mechanically inclined......thanks guys for the help ill try and get a pic of the area im talkng about and yes i do have a Manuel
jakedaawg
If it were mine I would try a new impeller and see how it goes. I personally don't have a lot of experience with salted up motors but I believe water dissolves salt.
mustangjay
Thanks impeller will b changed soon but. I dont think that is my problem as the head stays cool and water pumps out of the pee hole fine
Honorary Supreme Mariner
The exhaust cover is water cooled.----Sounds like there is a blockage there.-------You may have trouble removing those bolts to inspect this.
jakedaawg
I would wait for one of these salty dog guys to reply, but, if you can still get the gaskets you could pull apart the exhaust cover and plates and try cleaning them. However, I fear you would probably break all the bolts and cause yourself a headache trying to do so.
With that said, I have a small 3/8" impact by snap on that uses a small 7v battery, it seems to do real well on loosening salty bolts on the few salt motors I take care of. It does not have enough torque to actually break the bolts. Just pull the trigger and wait and it eventually shakes them loose.
mustangjay
Ya i was thinking i would have to take off the exhaust cover im going to call and see about gaskets today if i did open it up to check it out weekday are the chances that i would b able to re-use the gaskets the motor isn't caroded at all so I'm not really worried about the bolts being stuck i just don't want to wait to get tree gaskets to b able to do it..... does any one have a diagram of how the water travels thru the motor?
mustangjay
I'm not joking what im asking is if i take it apart can i use the same gaskets to put it back together to see if that resolvesmy issue then as soon as i get the gaskets ill replace the old ones I'm not taking the boat out on the water n testing it this is all in my drive way if it doesn't resolve my issue then ill move on to the next possible solution I'm just trying to make the best with my time instead of just sitting around and waiting a few days till the gaskets come in..... thank you all for your help
mustangjay
Cooling Questions
Compression is 130/130/125
No water coming out of gaskets on head
I will check the plugs n put sum oil on them n run the motor n see if there's water getting in the head
Thermostat was bad so i took it out till i get a new one
Its not over hearing at idle but when i run it at 2500-3000rpm the pee water gets very warm and the top part of the exhuast plate gets hot
This isnt my motor but thats where its getting hot aton the top where it slopes down hot to the point i can only hold it for a few seconds
mustangjay
I dont havw outboard experience so i may just b completely ovee thinking it and thats normal to get that hot and maybe the pee water normally gets that warm anyone with the same motor could u tell me if yours does the same?
mustangjay
fetch
fetch
GA_Boater
Moved your posts from the thread you hijacked. No need to post in other threads since you started your own. Look at the Help Tips on top of the page.
sutor623
140-160 degrees feels very hot to the touch. You could keep your finger there, but you wouldnt want to. I got an infrared thermometer from lowes for $20 when I thought I had a head overheating. Saved me a big headache when I realized it was just warming up to 143 degrees.
