Re: 70hp evinrude power issue
I fixed the issue on my 1984 70hp Johnson!
As per the Clymer's manual suggestion, I started at the fuel tank and worked my way back. Main line 5/16" hose was starting to crack, especially at the fuel pump. Also, with the engine running, fuel was pouring out of one of the T connections that feeds fuel from the fuel pump to the carbs. So, I also replaced the 5/32" hose and the two small T connections in that fuel line assembly. I used standard duty nylon cable ties as hose clamps on the 5/32" hose (I know this is not ideal, but the best I could find).
Also, while I was at the mechanic's buying the 5/32 hose and T-connections, he was pretty confident that this wouldn't fix my "Won't go fast" issue, as he put it.
So, since I already had the silencer plate removed to visually check if all butterfly's were opened at the same time and because of the mechanic's advice I removed the top cylinder high speed jet (Float Bowl Orifice Plug on shop.evinrude.com) with my skinniest screwdriver (I could see down the hole with a flashlight). The nozzle on the orifice plug was very gummed up and I couldn't see through it at all. After cleaning this one and the middle carb the same way, I just gently poked my cleaning tool into the bottom cylinder orifice since it would have been much more difficult to get it out of the carb.
Took her out yesterday after work and she ran like a champ!
To summarize, what I did to fix the issue and how long it took (Keep in mind that I'm no veteran):
1. Removed Silencer plate assembly to visually check that all butterflies were open at the same time (20 minutes)
2. Replaced most fuel line from tank to carbs (1 hour 15 minutes - does not include finding parts... 5/32" hose was hard to find on the weekend)
3. Cleaned float bowl Orifice Plugs, aka High Speed Jets, on all 3 cylinders (20 minutes). I didn't test on the water after replacing the fuel line, but I'm pretty sure that #3 was the main cause of my problem.
Good luck to you all and I hope to hear soon that yours are also running like new again!
