70hp 1992 Johnson stripped spark plug hole
DishMonkeySteve
Hi all I was just changing my plugs and I noticed only the top one of the 3 was black...I had noticed unburned fuel in the lake so I wanted to change the plugs.
The top one wouldn't thread in easily, so I looked closer and the (cylinder head?) threads were all torn up. I did my best to get the plug back in cause we have at least 2 more months of boating.
Looks like I need to replace the cylinder head part 0435981 but clearly I shouldn't even change my own spark plugs. Any advice would be appreciated thanks.
flyingscott
No need to replace your head but it has to be fixed SOON. A heli coil or insert will repair the threads nicely.. If it is not fixed there is a good chance that the plug wil come out and cause more.damage.
oldboat1
^^Agree. Not sure which model you have, but you have some repair choices: http://ww2.iboats.com/Cylinder-Crank...iew_id.1540448 .
You can purchase a new head cover, of course, along with a new gasket. You can look for a used head cover, or you can install a helicoil to repair the damaged threads. In any case, the head cover has to come off — not difficult, although salt corrosion can provide problems in a salt water motor.
A machine shop may be able to repair the damage for you or perhaps install a helicoil. Before reinstalling, you will want to resurface the mating surface of the head cover to get out any warpage, or have a shop do it. (Doing it yourself is very easy with a piece of wet/dry sandpaper and a perfectly flat surface.)
boobie
You don't have to remove the head to install the helicoil. I've done it many times. All it takes is some grease on the drill, tap and ect.
DishMonkeySteve
Thanks for the advice everyone. I'm relieved that I have another option.
We're in fresh water, glad I don't have to worry about salt.
