'70 Johnson motor dies when I push the throttle forward
JoeAggie
I was driving at full throttle when my 1970 Johnson motor slowed and then died. I can get it started but everytime I press the throttle forward the motor dies. Any ideas?
hondarider188
Re: '70 Johnson motor dies when I push the throttle forward
You could possibly be getting not enough fuel to run at a higher speed or even to much fuel. And does it have the high and low speed adjustments and of it does the high speed could be out of adjustment and need put back it proper aligment. But remember Im no expert but just have a idea
JoeAggie
I will check it this evening. I don't know about the high and low speed adjustments. I have had it out about 8 times since I got it with no problems. It ran great for about two hours and died on the way back to the boat ramp.
hondarider188
You could even have the timing or points are off. Hope you get it all fixed out and with the best of luck.
FillupD
The simplest thing I can think of is to make sure your fuel vent is open. That's were I would start anyway, scenario sounds about right.
Could it have warmed up and a crack in the coil open robbing you of power?
teddiego
I had that problem in reverse and it turned out to be a rope caught up and not allowing it to in gage
Daviet
Are you sure it is running on all cylinders? I would start with a compression and spark test, easy and cheap to do, if everything checks out ok, move on to the fuel delivery system.
