Steele329
- May 3, 2012
- 41
Hi, I need some help on this one. I went out and ran all day Saturday and my 70 ran fine all day. I went back out on sunday and had no issues until out of no where while running at top speed it seemed to gradually slow down but not quite anything too noticeable, just figured it was my imagination. Then when I slowed down to pull up to my favorite beach up spot, it just died. I from there could not get it started for almost a half hour. Once I was able to I had to choke it, then throttle it up to keep it running (in idle.) Once running, i put it into forward and it died again. The only way at this point to get it started was to choke it again even tho it was warm. After a number of tries i was able to get into a low speed and cruise back to the dock. Any attempt to speed up just killed the engine. In the past I knocked the wire off of the top cylinder not the spark plug end but the other end (I honestly dont know what this is called... Any help?) with this condition I assume I was running on two cylinders and the symptoms were similar, but not quite the same. Does this sound like anything anyone has dealt with? Any help is greatly accepted and appreciated. Thank you!
