70 johnson carb adjustment
jasonr83
ive got a 1990 70 johnson. When i turn the idle mixture srew out does that richen or lean the mixture. Its hard to tell while adjusting them. my carbs are about 1 1/2 turns out engine idles good but smells really rich and plugs are black. i know alittle rich is better than lean but i don't want to overdo it. thanks
stylesabu
Master Chief Petty Officer
Re: 70 johnson carb adjustment
the more you back it out the richer the mixture. sounds like heavy float or incorrect float level
stylesabu
if you can smell it,its probably running rich.
