snookstalker
Thread starter- Joined
- Mar 6, 2004
- 2
Hi, this is my first time on this post. I have spent many hours working on my motor, but I cant figure this out. The motor runs fine with the cover off, but as soon as you replace the cover it dies. I do see exhaust coming up from underneath the powerhead when I remove the cover. I assume the exhaust is choking the carbs out. The lower unit was recently serviced, and the mechanic had to cut a hole in the case to get the drive shaft loose. Is it possible he damaged the lower part of the powerhead getting the driveshaft loose? The motor will run fine when it is out of the water, but it dies as soon as you try to go out. Is this motor irreparably damaged, or does it need a powerhead rebuild? This is and 82 Johson 3cyl. Rebuild may be more than motor is worth....thanks.
