HELP PLEASE!! I have a 1991 70 HP Force. When I try to start it there is just a click at the solenoid. I put a new starter on it a couple of weeks ago. I thought that this was just a bad solenoid so I put a new solenoid on it but it still just clicks.
I checked the input side of the solenoid and I have 12V coming from the battery. I check the little yellow wire on the solenoid and when I turn the Key to start position I get the full voltage. I checked the out put side of the solenoid and it barely had any voltage when the key was turned. I tried to jump the post on the solenoid with a screw driver and it sparked just a little but still did not activate the starter. I checked the gound on the solenoid and it appears to be okay.
As a last resort I took the positive cable off of the battery and then went to the solenoid and took the output cable going to the starter and hooked it to the input side of the solenoid with the positive lead that runs straite to the battery. I then touched the positive lead to the battery post and the starter jumped.
I'm not a mechanic, but this does not seem like it should be this compicated, yet it has me compltely stumped.
