pnflaitz@infoblvd.net
Thread starter- Joined
- Nov 18, 2001
- 5
Every once in a while the engine will get very sluggish and won't even run enought to plane the boat. Give it a few minutes and it might take off again or it may be a long ride back to the cottage. A couple of times it has happened after the boat has been cruising at a decent speed for a while. It's almost like the engine just doesn't want to go anymore. It always idles fine and runs great at lower RPMs. Never had a problem with starting or stalling. Any ideas on what this might be. Not too technical, I'm new to all of this
<br />Also, I changed the lower unit oil and didn't pay attention to which screw went on which spot. One has a longer tip on the end of it and the other one is a lot shorter, but both the same diameter. Any ideas. I think the engine is a '78 or '79.
