I have a 1984 70HP Evinrude that when hooked up to a garden hose and adapter puts out much hotter water than a 1971 60HP Evinrude I have? I'm talking the difference of luke warm water on the 60HP and hard to hold your under the water temp on the 70HP? The last time I used the boat, it quit running for a while then started up again later on. Maybe after cooling down? I thought it was an old gas problem as to why it stopped. How can I tell what temp. it is running at? And what water temp. coming out while on test hose should be OK? Thanks so much guys. Dave
