70 HP Evinrude outboard Problem with power trim
Dolson703
the power trim for my motor, witch is a 70 hp outboard motor, it will not go up and down the relay clicks but that is all but when i took the battery out and cleaned the wires and i had all the wires on the positive and i put only 1 wire its a double wire its really small, then i tried to use the trim it hummed but when i put everything on it just clicked what do i do
Dolson703
Re: 70 HP Evinrude outboard Problem with power trim
it is a evinrude 70 hp motor not sure on the year adout 1980 somthing i think
