70 hp and 90hp bottom ends
myeengun
I banged up the bottom end of my 70hp Johnson... still runs but only forward, lost reverse. I have a chance to buy a 90 hp Johnson.. just wondering if the lower ends are compatible?
jimmbo
Chances are between very slim and none. You haven't mentioned yrs of either so... For one the gear ratios are very different, 70(29:12), 90(2:1 post 1980) or (23:20 1964 and 65), it would be hard or impossible to find a prop with a low enough pitch. Shifting design may be different, depending on the years. The 70 could have a hydro-mechanical or plain mechanical shift. a 90 could be electric(1964 - 65) or post 1980 plain mechanical. Driveshaft splines are probably different. An electric case from the 1960s could never bolt onto a 3 cylinder engine.
You say your current engine only has forward, no reverse. What about neutral? Control box good? Cable good and connected?
No reverse because the shift mechanism bore is damaged.-----Reverse is a down motion and it can not make full travel.-----Did oil leak out ?------Is propshaft bent ?------No a 90 hp unit will not fit.-----Model # or year of the 70 HP is ?----Your location ?
