70 hp 1981 Johnson
msumrall
Three problems - I am a new boat owner. (2nd)There are 7 or 8 bolts that hold the leg (?) to the powerhear. At least 4 have broken off in the Powerhead. Water is being pumped out between the PH and the Leg. What may have caused the bolts to break. What are the problems I may encounter fixing this problem? I have some mechanical skill. (3rd)When I put the cover on the motor it quits running. Remove the cover and the motor cranks and runs, no problem. Can the 2nd problem cause this fluke?
ob
Re: 70 hp 1981 Johnson
minuteman,whether you are refering to the bolts that retain the lower unit to the midsection,or the ones that retain the midsection to the powerhead ,corrosion is a common factor.It is also possible that swell from oxidization on the horizontal joint could cause already weakened bolts to shear off.If water leakage is excessive it can cause problems with under cowl wiring and cooling of the exhaust housing within the midsection depending on where its leaking from.<br /><br />As for the engine dying when motor cover is installed,one of two things could be the culprit.You either have an exhaust leak that essentially suffocates the engine by being sucked into the intake silencer,or you have a lower cylinder sparkplug lead that is going to ground on the motor cover latch.
msumrall
I don't know what all the parts are called, but this part is bolted and covered by the part the hood/cover latches.
