70 Horse Johnson Alarm Sounds
WALLEYE HUNTER66
Got a 70 Horse Johnson .. Whats going on i can run the boat for an hr or two when on plane the alarm sounds and engine goes into slow mode ,,I stop shut down engine wait about 2-5 minutes motor fires right up can run another hr or less and alarm goes off again,,,Back into slow mode ,,,engine shutters and can not get above 8mph ,,,idle back to docks load up and the next day same situation get started run good for an hr or two and alarm goes again ,,, Im Running my fuel Pre mixed and it also has a oil tank on it also ,,,i am running VRO and Pre Mix ,,,, ANY HELP
Joe Reeves
Re: 70 Horse Johnson Alarm Sounds
Strongly advise to drop the lower unit and install a new water pump assembly.
WALLEYE HUNTER66
She pumps water and water coming out of pee hole ,,, some days she runs with no issues at all it has me stummped
MikeB0307
I'm with Joe. Stream or no stream, replace the water pump. Also, if it hasn't been done in a while, replace the thermostat. Better safe than sorry. Much cheaper than replacing the power head if it overheats some more.
WernerF
And when you change the thermostat you can also get a clue if to expect some more debris in the cylinder head water passages.
The temp sensor rarely goes bad; the overheat alarm is almost always right.
Try to get/borrow an infrared temp gauge.
Watermann
I'm with Joe and Mike... water pump and thermostat.
WALLEYE HUNTER66
Replaced Thermostat ,,,, Also I am Pre Mixing my fuel ,,I mentioned it to mechanic and he said there is a sensor in oil tank also ,,,Dumb Dumb Me I have not put oil in that tank since i had the boat since i pre mix ,,So here is what we did Unhooked electric oil Pump just dissconected wires,, Took boat to the lake , She ran up to 38MPH and the Alarm never went off ,, PROBLEM FIXED ,,,Thanks for all Your Helo Guys .....
