Re: 70 Force
Before you mess with the carb, change the plugs. Fouled plugs often lead to a low idle speed and stalling when put into gear. If that does not help, the check the idle speed--it should be 700-750 in forward gear in the water. If it is not correct, then set it using the idle stop screw on the carb/timing tower.
