Re: 70 Evinrude throttle shafts loose in carbs
Yes..you can resleeve them...but try this it will be quite a bit easier.<br /><br />I assume you are having problems with the low end..lean pop?<br /><br />If so..just increase the low speed jet by a couple Thou..for instance if your jets are .062 drill them out to .064.<br /><br />This should take care of your problem.<br /><br />TMD
