7.5 HP Ted Williams wont run on remote tank!!
esimone80
I have 1975 Tedwilliams 7.5, model #217585910. Engines runs on built in tank, wont run on remote tank w/o using choke pulled part way. Did not have original tank connector, Using a chryler/Force connector appeared to be the same style. Any suggestiions or thoughts!!!!
steelespike
Re: 7.5 HP Ted Williams wont run on remote tank!!
Be sure pick up tube is clear,vent is open and working,Does the primer bulb collapse?<br /> Check the fuel pump.The Chrysler/Force connector should work but be sure it doesnt suck air.
norman158
do you have a shut off valve on your built in tank? if so close it then try the remote tank.
