7.5 horsepower ted williams
shawshank1111
I Have A 7.5 Horse Power Ted William, I Need To Know A Little About This Motor. If Someone Could Help I Need To Know The Fuel Ratio , Year , Lower End Unit(what Gear Oil Do I Need To Put In}. The Only Numbers I Have Are 217-5889-0 And 3d-180814, Any Help Would Be Appreciated
steelespike
Re: 7.5 horsepower ted williams
Motor is a 73 built by Eska for Sears.Fuel mix is 24:1 use 2 stroke oil for chain saws/weed eaters etc.as it is an air cooled Tecumseh power head.
It has a water cooled exhaust leg and water should mist out of the relief holes on the leg.Any quality outboard gear lube for the lower unit.
Parts for the power head may be available at a small engine shop.
Cetrified parts corp for parts as well and Sears may have some parts.
shawshank1111
Are you sure about the fuel mixture. Could it be 40:1. I just took it out and it was not right thanks
shawshank1111
another question, where would i get a new water pump for this?
steelespike
Generally too rich fuel mix will not affect performance.It will just smoke more
and possibly foul plugs over time.
That said Eska to 73 24:1 74 up is 32:1 Oil is the life blood of a 2 stroke I wouldn't mess with the mix for 1.3 ozs per gallon.
