7.5 gamefisher
bobsbb
i would be extremely grateful if anyone could help me on this.i just bought a used boat and it came with this motor.it has worked great but i went to move the fuel tank and the fuel line popped off the motor.now i can not find where it connects back to the motor.i called several repair shops and no one will work on them.any suggestions?i live in orange county.also, i am not sure but i think i found the hole it plugs back into,however,there must be another piece that came off because the line and clamp would be in the way of the linkage.the fitting is still in the hose and looks like there is no sign that anything broke off the fitting.even if i could just get a diagram of the carb it would help.thanks
crazy charlie
Re: 7.5 gamefisher
Sears has a good website sears parts direct.com you can get to a diagram of the part.Charlie
steelespike
Re: 7.5 gamefisher
A model number would help,usually on the mounting <br />bracket.A number of companies built motors for <br />Sears.Some use what is called a Chrysler connector<br /> It remotely resembles a quick connector from<br /> an air line or water hose.It is possible the<br />motor piece broke off and is still on the end of the hose.
