7.5 Game Fisher
RStangarone
I have a 1980 7.5 Game fisher. I pulled the flywheel off to clean the points. There was a green wire that went to the cutoff connection at one end and the other end was just dangleing. Anyone tell me where to stickit. Ok be nice now.
grehmer
Re: 7.5 Game Fisher
I will open mine to see where that wire is connected. Not to highjack your thread but I would like to ask a follow-up question;
I also have a 7.5 Gamefisher that runs great however the prop does not turn when put into gear. Is there some sort of pin/key that may have sheared off preventing the shaft from turning?
Tom @ Buzzard Bluff
Re: 7.5 Game Fisher
Since the kill function grounds the coil output to prevent ignition then it most likely goes to the points.
<I also have a 7.5 Gamefisher that runs great however the prop does not turn when put into gear. Is there some sort of pin/key that may have sheared off preventing the shaft from turning?>
If the propshaft turns when in gear but the prop remains stationary then the shear pin is sheared. If the propshaft doesn't turn then you have a more serious problem somewhere in the drivetrain.
