zavalanche71
Thread starter- Joined
- Jul 7, 2005
- 10
Re: 7.4L MPI Engine turns over but immediately stalls
Waterone1, is there a website that I can find this service bulletin? I cannot find a place on the mercruiser website with any service bulletins. I have a Clymer service manual but if you think I need a mercrusier service manual, I will order one. I do not believe the fuel pump was ever replaced. I bought this boat from a dealer with 18 demo hours on it. I have had it for about 5 years and only have 90 hours now. <br /><br />What is the best way to check the lines from the tank to the fuel pump? In this configuration the line comes from the tank to the fuel filter/water separator (located in a plastic 2piece case) and then goes under the engine from the left side to the lower right side and the fuel pump is in a casing far low on the right hand side. I believe the engine needs to be pulled in order to service the fuel pump. Do you have any suggestions for testing the line?<br /><br />Meanwhile, I ran the boat for about an hour yesterday. It ran fine, temperature never went above 160 +/-5 degrees. Again, this is just like how it performed before when after a few more hours I ran into a problem. <br /><br />Since I do not see any gasoline glaze on the little water by my bilge, so I assume if there is a pinhole it must be before the fuel pump.<br /><br />Could a bad IAC or pressure regulator allow air into the fuel rail?<br /><br />Newport Dave, I am located in Michigan, so it is not extremely hot weather here. I agree somehow the air is getting in the fuel rail. Nothing has been taken off the engine, so I assume the heat shields are there. As I mention above, the fuel filter/water separator is located in a 2 piece plastic casing. Any other ideas on how potential vapor lock can be found in the rail?
