7.4 liter intake manifold
cmarkham416
I have a 7.4 liter and im trying to get the intake manifold off. I removed the risers and manifolds, as well as the intake manifold bolts and I still cant get it to budge. Any suggestions?
alldodge
Re: 7.4 liter intake manifold
:welcome: to iboats
If you have all 16 bolts out it's probably just stuck. Many use an adhesive and can be quite stubborn. Do you have a cast aluminum or iron intake?
tpenfield
Distributor off?
even then, they usually need a bit of persuasion
cmarkham416
:welcome: to iboats
I have an iron intake.
Volphin
Once the distributor is out, take a putty knife or big exacto and slice through the RTV seal on the fore and aft areas of the manifold. I know it's tempting, but don't wedge a screwdriver in there and pry on it. You can damage the sealing surfaces. The carb or TB and all cables must be disconnected as well.
alldodge
With it being iron you shouldn't have to worry to much about breaking it. As Volphin mentioned you want to take care not to damage to sealing surfaces but there is usually edges which can be used to pry. The issue is don't drive a screw driver under the surface, I've used them on the corners and with iron you can do a little prying, but don't go hulk on it
cmarkham416
Thanks everyone
