kschnebly
- May 15, 2013
- 64
My 7.4 mercruiser has left me needing a tow three trips in a row. The boat runs amazing as long as we cruise under 4000 rpms. We can go full throttle at takeoff and it runs perfect. If we cruise at over 4000 rpms it will bog down and die after a few miles. Only takes a few seconds between running great and dead in the water. Won't restart for 4-5 hours. Smells like gas. I've cleaned the distributor contacts, replaced the coil and checked all other connections. The boat was in storage for three seasons. I emptied fuel tank and ran lots of sea foam. Tonight I pulled the carb and fuel pump to check them out. I noticed I had some fuel in my crank case so I'm not sure if it's from it being flooded so much. Lots if cranking without it starting. I felt I should rebuild the carb anyways since it sat. Just looking for something I may be missing. It's a big boat and dealing with it dead in the water is a bummer.
