I'm reassembling the lower unit/gearbox on my Johnson 6R71G, but now when I go to test it, it only smoothly shifts into forward and reverse. I've been at it for a couple hours and close to getting frustrated.
Attaching the shift rod linkage is pretty difficult by myself, but I'm wondering if there is any method to the madness I'm simply missing. To get to the bottom bolt on the shift linkage piece that connects the two rods together, the shifter needs to be in reverse (shift rod all the way down in the exhaust housing). The service manual indicates the shifter needs to be in reverse, so I try to slide that last 1/2" up on the shifter lever without pushing the short shift rod down.
I put two of the six bolts in the lower unit to test, but it will not go into reverse so it's back to square one. Does anyone have any suggestions?
