I'm "de"converting this from a long shaft (+5") to a short shaft to accommodate a short transom boat. I've disassembled the lower unit from my Johnson 6R71G without much fuss. A couple problems I'm seeing before getting too frustrated and making a stupid decision.
1) The short drive shaft (part #0381026) and lower shift rod (part #309582) I ordered from a fleabay vendor look wrong. Shift rod is exactly the same as what was in there and the drive shaft splines on the end aren't similar at all. I will return both it if anyone can verify it is indeed not going to work.
2) If/when I do get the correct drive shaft ordered, how the heck to I remove the pinion gear on the bottom?! This is where BFH came into my mind and I stopped.
3) I tried my best to order what I thought was the right parts, but evidently I'm wrong on most fronts here. Can anyone tell me/point me in the right direction to what I should have ordered?
http://eu.readmanual.com/parts/outboard.motors/johnson/1971-6-6r71g-parts-catalog/Gearcase-7.htm
